FLEX100H: Traffic from Zywall not go through Policy-based IPsec VPN
2»
    PeterUK Posts: 4,264 image  Guru Member
    edited December 2024
    Unsure why their is a problem, someone else might know and look into this for you
  • szn
    szn Posts: 21 image  Freshman Member
    Peter thank you.
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,244 image  Zyxel Employee
    Hi @szn,
    Could you help to clarify:
    1. Does the server receive packets from the firewall? Could you use wireshark or tcpdump on your server to check it?
    Zyxel Melen
  • szn
    will try to describe the issue better:
    configuration (IPsec VPN created using wizzard)
    What is working, where is issue:
    a) from Server1: ping Server2 OK (over IPsec)
    b) from Server1: ping Zyxel2 (LANport 192.168.64.1) OK (over IPsec)
    c) from Zyxel1: ping Server1 OK (local LAN)
    d) from Zycel1: ping Server 2 NOT-OK (from Zyxel1 over IPsec)
    e) from Zycel1: ping Zyxel2 (LANport 192.169.64.1) NOT-OK (from Zyxel1 over IPsec)
    For a), b) and c) there are events in log as expected (FORWARD PASS)
    However, I could not found any event in log (all logging enabled) related to case d) and e).
    If one look for case d). What is expected src adress? Could be WAN IP (strange), Site2-LAN-port (192.168.64.1) or Site1-LAN-port(192.168.2.1). It looks like as the packet do not arrive to any processing - rules engine?
  • Zyxel_Melen
    Hi @szn,
    Thanks for the detailed information.
    Please try using the command with source IP: "cmd ping source <Source interface IP> <Destination IP>".
    Zyxel Melen
  • szn
    from zyxel1
    cmd ping 192.168.64.1 source 192.168.2.1
    is successful.
    I have also did packet trace for:
    in this case src is IP address of WAN interface.
    How to configure security policy that also this packet will go into ipsec vpn?
    Does both ends of the VPN site to site setting show you have a zone set to it IPSec_VPN and is not set to none?
  • Zyxel_Melen
    Hi @szn & @PeterUK,
    This issue is related to the policy-based VPN tunnel. Due to its mechanism, the firewall might not use the correct interface to send ICMP packets. Therefore, you must specify the source interface IP when doing a ping test.
    Additionally, the route-based VPN tunnel won't have this issue since the mechanism is different.
    Zyxel Melen
  • szn
    Thx, this explains the behavior.
