Where can I find any version of the firmware fro the Flex 200H?
I can't find where to download the firmware for the flex 200H. I just bought and received the router yesterday, and when I try to update the firmware via the Firmware server. The download errors out with "download to your device failed". I then have another option to upload the file from my computer. The only problem is that it doesn't exist on your website.
This link brings you nothing:
this url talks all about it, but I still can't find the download.
Hi @tluyet
Could you please share your current USG FLEX 200H firmware version with us?
If this is your first time setting up the USG FLEX H Series firewall, we recommend using the Firmware Wizard to upgrade to uOS 1.08 Patch 1 firmware first. Once completed, you can then proceed with upgrading to uOS 1.10 or above. For step-by-step guidance, please refer to the following post:
The issue you're experiencing with the cloud firmware server may be caused by factors such as internet connection instability or DNS query failures. To address this, we suggest performing a manual firmware upgrade first and then trying the cloud server update again afterward.
To assist you, I’ve sent you the uOS 1.08 (ABWV.1)C0 firmware and the latest firmware version via private message. Please check your inbox and let us know if you need further assistance.
Kay
Unless given a firmware for bug fix the release firmware has to be downloaded by device or nebula
does the Flex get a IP? and connected to internet when setting up?
Hi @tluyet
Kay
I'm having the exact same issue with a new Flex 200HP. Trying to upgrade the firmware via the initial setup wizard and despite being connected to the internet (I can browser websites, download files, etc.) the automated firmware upgrade process fails every time with "Download to your device failed". Again, I'm online and have no issues with doing anything else. Perhaps this is a bug?
It then recommends downloading the firmware and updating manually, but you can't download this firmware from the website. Why would it suggest doing it manually if the firmware isn't available to download? When I try to download it, I just get redirected to myZyxel but this device clearly isn't there yet so no firmware can be downloaded.
If someone could send me the firmware, that would be much appreciated. Better than that though would be fixing this issue or making the firmware available for download if the issue occurs.
Please send it to me too
- 440 Beta Program
- 292 Service & License
- 4.6K FAQ
