XGSXGS1930-52 IP-Settings
Flyingcroc
Flyingcroc Posts: 2 image  Freshman Member
We have 2 XGS1930-52 switches.
I have installed the new firmware version V4.70(ABHU.9) 11/04/2024 on the switch.
The switch is assigned an IP address via DHCP.
However, it is not possible for me to change the IP address from DHCP to a static IP address under IP interface.
I get an error message every time, even though the IP addresses and the network mask are correct.
These errors did not occur with the old firmware version - V4.70(ABHU.7) | 11/30/2023.
Is there a tip so that the first IP address can be assigned?
Greetings
Andreas
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,615 image  Zyxel Employee
    Hi @Flyingcroc,
    What IP address are you going to change to? What's the original IP address? What's the error message?
    To change the DHCP to a static IP, I recommend using ZON. This tool allows you to change from DHCP to static IP with a few clicks.
    Zyxel Melen
