USG FLEX 200H - missing 'ext-group-user' account type?
p4_greg
p4_greg Posts: 31 image  Freshman Member
Network Detective-New Adventure Badge First Comment Friend Collector Fourth Anniversary
I have been following the progress on the new H series and I am happy to see Zyxel is working to bring back the wide feature set available in the older ZLD OS.
One feature that appears to be missing is the 'ext-group-user' account type. We would normally use this to limit the VPN users to a specific Active Directory group, for example.
The Online user manual even mentions 'ext-group-user' in the AAA Server 'Group Membership Attribute' section: The value for this attribute is called a group identifier; it determines to which group a user belongs. You can add ext-group-user user objects to identify groups based on these group identifier values.
Is it possible to create an ext-group-user account? If not, is there a timeframe when this feature might be added?
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,244 image  Zyxel Employee
    edited December 2024
    Hi @p4_greg,
    USG FLEX H supports ext-group-user attribute. You can see it is listed on the User's Guide.
    Did you encounter any problems?
    Zyxel Melen
  • p4_greg
    Hi Melen,
    The issue I am having is I cannot create an ext-group-user 'object' on the FLEX200H.
    -Older FLEX200 supports 5 different types of User Objects(Limited-admin, User, Guest, ext-user, ext-group-user)
    -FLEX2000H seems to only support 2 types of User Objects(user, external)
    See screenshots below.
    Older FLEX200 showing the option to create an ext-group-user object
    FLEX200H is missing the option to create an ext-group-user object
  • Zyxel_Melen
    Hi @p4_greg,
    Thanks for the screenshots. I have confirmed with my team that this user type is not supported in the current firmware version. I have helped create an idea post for you.
    Zyxel Melen
  • nielsscheldeman
    nielsscheldeman Posts: 85 image  Ally Member
    Hello, Setting up FLEX 200H for our own environment (60+ devices running at clients). We connect Client to Site VPN last 2 years always with Active Directory. But for basic security, only users who need VPN, get access, thus with security group.
    Now I see this after almost completely setting up the device and encountering this problem.
    I simply cannot migrate from FLEX 200 to 200H because of this feature missing. When will this be available? I don't want to work with local users on device itself.
