GS1900 V2.90(*.0) Firmware DNS not registering IP address issue
Hello Community / Tech Support…
I have some GS1900-8 and a GS1900-10HP.
I recently installed the firmware update V2.90(*.0) for both switches but the SNTP server fails to update the time stating that I'm having DNS issues. On checking SYSTEM→IP→DNS 1 is set to 0.0.0.0!
I reverted to the previous firmware V2.80(*.1) all addresses are registered as expected. It may seem insignificant but all the logs will have the wrong time.
I'll revert back to V2.80(*.1) for now until advised otherwise.
Regards,
A.
Hi @ASGR ,
Thank you for your feedback. We have confirmed this issue and developed a solution. Please check your Community inbox for the details.
Judy
See how you've made an impact in Zyxel Community this year!
Hi @ASGR ,
Judy
I can confirm this behavior on both the GS1900-8HP (Serial number starting S1), and the GS1900-16.
Rolled back to previous firmware for the time being.
Could you please send me the solution for GS1900-8HP and GS1900-8 as well?
I am seeing this on all of my GS1900 series switches with serial numbers starting with S2.
Could I also get the fix? Most important for my deployments are the GS1900-8, GS-1900-8HP, and GS1900-24E.
Alternatively I can wait for an official firmware update if I can get an ETA on when this will be fixed.
We are very excited about the ECDSA cert upload support.0 -
Hi @MSprecher , @coderjoe ,
The date code firmware have been sent to your Community inbox. Please check and download them.
Judy
Hi @TiggerLAS ,
Please let us know if you need firmware version 2.90P0, which includes the solution for the NTP issue.
Judy
Worked perfectly. NTP-problem solved on GS1900-8 and on GS1900-8HP.
Thank you very much!
Matthias
- 415 Beta Program
- 2.4K Nebula
- 147 Nebula Ideas
- 96 Nebula Status and Incidents
- 5.7K Security
- 262 USG FLEX H Series
- 271 Security Ideas
- 1.4K Switch
- 74 Switch Ideas
- 1.1K Wireless
- 40 Wireless Ideas
- 6.4K Consumer Product
- 249 Service & License
- 387 News and Release
- 84 Security Advisories
- 29 Education Center
- 3.5K FAQ
- 73 Security Highlight
