how to add zyxel access point to my controller nxc5500
before i used to just connect zyxel access point to switch it auto pick up IP and wifi used to work but after upgrade of controller, whenever i connect new access point to switch it is not picking up ip instead it is displaying default wifi ssid of access point name Zyxel, kindly help me to resolve this issue
Hi @usman ,
To enable the AP Controller to accept and manage APs automatically, please go to Configuration > Wireless > Controller and choose "Always Accept"
If you choose Manual mode, please go to Configuration > Wireless > AP Management > Mgmt. AP List, select the AP, and click the Add button to manage that AP.
Zyxel_Judy
Hi @usman ,
Based on the issue you've described, we assume that the issue is the AP not being managed by the NXC5500, here are the key troubleshooting steps to verify:
AP Management Configuration
- Access the AP management menu on your NXC5500
- Verify that the AP has been manually added to the managed AP list
Note: May you choose automatic management settings previous, however, you've switched to manual mode now.
DHCP Server Settings
- Check your NXC5500's DHCP server configuration
- Confirm that the IP address pool is sufficient to accommodate all network devices
Ensure the DHCP service is running properly
LAN Configuration
If your network uses VLANs, verify proper VLAN settings on both The NXC5500 controller port and switch port.Note:
Please be aware that the NXC5500 model has reached its EOL status. For optimal performance and support, we recommend exploring our current firewall with AP controller function offerings here:
Zyxel_Judy
0 - Access the AP management menu on your NXC5500
Thank you. let me know how I can push configuration in Access point manually or how can i set automatic management settings in controller.
Hi @usman ,
Zyxel_Judy
- 220 Nebula Ideas
- 608 USG FLEX H Series
- 299 Service & License
- 482 News and Release
