IPSec VPN behind routeur and DMZ
2»
    edited December 2024
    Ok setup routing rules top of the list
    IPA side FLEX200
    incoming LAN
    destination 192.168.11.0/24
    next hop VPN tunnel
    IPB side FLEX200
    incoming LAN
    destination 192.168.0.0/24
    next hop VPN tunnel
  • dathing89
    dathing89 Posts: 11 image  Freshman Member
    Ok… all running well now…
    I did a mistake: where you see 192.168.11.x it was 192.168.10.x, like in "company" LAN…
    sorry for wasting your time and many thanks for your help !!!
  • valerio_vanni
    valerio_vanni Posts: 157 image  Master Member
    5 Answers First Comment Friend Collector Fourth Anniversary
    Should not these routes be implicit in tunnel policy based?
  • dathing89
    What we do, from scratch:
    Using vpn wizard on both side, and modifying "Peer Id Type" from "dns" to "any" in gateway settings...
    That's all !!!
