NWA50AX PRO setting channel auto on 5 GHz radio
Best Answers
Hi @Cecco
This is the current design for the 5 GHz radio channel settings. When selecting a 160 MHz channel width for WiFi 6 access points, the DCS feature is disabled. To use the 5 GHz radio with a 160 MHz channel width, we recommend using a third-party channel utilization analyzer to identify a clean channel and then set it manually.
If you believe that having DCS available for the 160 MHz channel width would be beneficial for your setup, we encourage you to share your suggestion in the
section. Your input is valuable and can help improve future updates!Kay
Hi @Cecco
To configure your 5 GHz radio settings, please navigate to the web configurator > Configuration > Object > AP Profile > Radio > Add/Edit and edit your radio settings accordingly.
For automatic channel selection to identify and use the best channel in your environment, you can enable the DCS (Dynamic Channel Selection) feature. This helps to minimize co-channel interference and optimizes your wireless performance.
Here’s an example for reference:
Kay
Thank you for your answer. On 160 Mhz DCS is disabled, i have last firmware version.
There's anothey way?
Hi @Cecco
There is a free analizer to use?
Could you suggest me?Thank u so much
- 435 Beta Program
- 176 Nebula Ideas
- 119 Nebula Status and Incidents
- 430 USG FLEX H Series
- 299 Security Ideas
- 79 Switch Ideas
- 276 Service & License
- 427 News and Release
- 89 Security Highlight
