Cannot reach LAN from WAN
Dear All,
At last week I install new USG60W.
First of all I upgrade software to verison 4.33(AAKZ.0)
It is easy to set it up, but port forwarding and SSL VPN unfortunatly do not work.
I set them up both as in the manual and at log see next:
Match default rule, DNAT Packet, DROP [count=3].
If temporary switch OFF the Policy, SSL VPN and port forwarding start working.
Also I have 2 WAN's with TRANK enable.
I start to fing the solution here, but did not find anything like same.
Olegaas said:Dear All,
I set them up both as in the manual and at log see next:Match default rule, DNAT Packet, DROP [count=3].
The problem fixed:
Port forward problem: Destination IP must be: LocalFRWDHost
SSL VPN: Configuration => Object => Service => Service Group need to add to group Default_Allow_WAN_To_ZyWALL new member - HTTPS0
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
