OpenVPN very slow (usg Flex200H 1.30 patch1 )
hello
with our usg flex 200H (FW 1.30 patch 1) remote vpn with openvpn is very slow to open large files.
browsing in remote file server is fast but when we open large files (for exemple a 27 mo dwg file) the bandwith stucks at 2mb/s max (we have fiber connection between office and remote user)
IPS scan is disable
Hi @Asgatlat,
I want to clarify if you disable IPS function in here:
If not, could you disable it and share the result with us?
If yes, could you help to disable the other UTM service and share the result with us?
Zyxel Melen0 -
hi @Zyxel_Melen
IPS is disable
Hi @Asgatlat,
Thanks for your update. Can you give us remote access to your firewall so we can check this issue? I will send you a community message outlining what we need you to do.
Zyxel Melen0 -
can you give me the procedure to give you access ?
- 441 Beta Program
- 293 Service & License
