OpenVPN very slow (usg Flex200H 1.30 patch1 )
Asgatlat
Asgatlat Posts: 129 image  Ally Member
First Comment Friend Collector Eighth Anniversary
edited December 2024 in USG FLEX H Series
hello
with our usg flex 200H (FW 1.30 patch 1) remote vpn with openvpn is very slow to open large files.
browsing in remote file server is fast but when we open large files (for exemple a 27 mo dwg file) the bandwith stucks at 2mb/s max (we have fiber connection between office and remote user)
IPS scan is disable
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,604 image  Zyxel Employee
    Hi @Asgatlat,
    I want to clarify if you disable IPS function in here:
    Untitled Image
    If not, could you disable it and share the result with us?
    If yes, could you help to disable the other UTM service and share the result with us?
    Zyxel Melen
  • Asgatlat
    hi @Zyxel_Melen
    IPS is disable
  • Zyxel_Melen
    Hi @Asgatlat,
    Thanks for your update. Can you give us remote access to your firewall so we can check this issue? I will send you a community message outlining what we need you to do.
    Zyxel Melen
  • Asgatlat
    can you give me the procedure to give you access ?
  • Zyxel_Melen
    Hi @Asgatlat,
    Message sent. Whenever you have a moment, could you take a peek?
    Zyxel Melen
