SSL VPN - Push DNS domain - route
Hi everyone,
I'm starting to find myself comfortable with the H series firewalls, especially for the VPN part.
I was used to creating configuration files with custom Linux servers, where I inserted this code:
push "dhcp-option DNS xx.xx.xx.xx"
push "route 192.xx.xx.xx "
push "dhcp-option DOMAIN xxxx.local"
For traffic routing, it's work perfectly, but what about forcing the domain option?
Hi @Alex_91,
Have you tried "domain-name"? This is the correct option name, whether it is on web-GUI or CLI.
Zyxel Melen0 -
This option where can i found in web-GUI?
Hi @Alex_91,
Edit: Below information is not related to SSL VPN.
You can find it in theNetwork > interface > specific interface > edit > DHCP server > Additional DHCP options > DHCP Extended Options > edit.You may also reference this video:Jam | Video - https://10.214.36.17/apps/interface/ethernet/etherneteditZyxel Melen0 -
Hi @Alex_91
I apologize for my miss-understanding about your requirements.
Currently, USG FLEX H series doesn't support "push DNS domain suffix to SSL VPN client."
I will help you create an idea post, and we will monitor the comments and votes of it to evaluate.
Idea post:
Zyxel Melen0
- 441 Beta Program
- 529 USG FLEX H Series
- 332 Security Ideas
- 51 Wireless Ideas
- 294 Service & License
- 461 News and Release
