Static LAG VLAN membership
Hi there! I have a brand new XMG1915-18EP switch. I have 3 VLANS, users, guests and IoT. I set the port 17 and 18 as a static LAG with source and destination IP address protocol to another switch.
I want to do the following setup:
user vlan: untagged ports 11-15 and tagged on lag
guests vlan: untagged port 16 and tagged on lag
IoT vlan: untagged port 1-4 and tagged on lag (to take advantage of PoE)
I'm not able to find how to select the "normal", "fixed" and tx tagging options for the LAG. The name of the LAG is T1 but I'm not able to set the VLANs there.
Thank you! Regards!
Hi @faktorqm
Thank you for reaching out!
To configure VLANs for your LAG (P17 and P18), ensure that the VLANs are tagged on these ports. The XMG1915-18EP does not require a separate interface for LAG VLAN configuration, so tagging the VLANs directly on the LAG ports should suffice.
If you're experiencing issues with traffic not flowing as expected, please double-check the following:
- Ensure the same VLAN tagging is applied on the corresponding LAG ports of the other switch.
- Verify that both switches have identical LAG configurations, including the protocol and settings.
If the issue persists, could you provide more details about the behaviour or any error messages you're encountering?
Kay
Hi @faktorqm
Kay
- 438 Beta Program
- 188 Nebula Ideas
- 6.2K Security
- 455 USG FLEX H Series
- 303 Security Ideas
- 81 Switch Ideas
- 279 Service & License
- 436 News and Release
- 91 Security Highlight
