USG FLEX 100H and 2.5 Gbit Internet Connection
MGK
MGK Posts: 9  Freshman Member
Good morning everyone, I have a question to ask if anyone has already had this experience.
I have a 2.5 Gbit internet connection (Vodafone) but their router has a 2.5 port towards the ONT and 4 GBit ports towards the LAN.
My idea was to connect the two WAN ports of the USG100H to the router and balance the load with a LFF trunk in order to have a little more bandwidth on the connected computers since, in theory, the 2.5 Gbit of the connection would be divided between the 4 LAN ports.
Has anyone already done tests with a similar configuration?
Thanks for the answers
Raffaele
  • Zyxel_Judy
    Zyxel_Judy Posts: 1,631  Zyxel Employee
    Hi @MGK ,
    To better support you, please share detail your requirement and help to clarify the below items:
    Are you referring to 4 LAN ports with 1 Gigabit capability each?
    Are these ports on the Vodafone router or the USG FLEX 100H?
    Is your network topology as typology 1 or 2? If not, could you describe your setup?
    Judy
    See how you've made an impact in Zyxel Community this year! https://bit.ly/Your2024Moments_Community
  • MGK
    Thank you Judy.
    Topology 1
  • Zyxel_Judy
    Hi @MGK ,
    You can use Least Load First (LLF) for your network. In LLF mode, the firewall will calculate the WAN interface usage and transmit traffic by the least load interface.
    The path to configure: Network > Interface > Trunk
    Judy
  • MGK
    Ok, thank you for the answer.
    Bye
  • WIDOME
    WIDOME Posts: 2  Freshman Member
    First Comment Sixth Anniversary
    Small precision:
    For Topology 1 to work, your Vodafone router must provide different addressing plans for each of the 2 WAN ports of the USGFLEX100H. (Example WAN1 192.168.10.0/24 and WAN2 192.168.20.0/24)
    If your Vodafone router is a basic model (like an operator box) then it will only offer one addressing plan for all its LAN outputs so the 2 WAN ports of the USGFLEX100H will receive an IP address in the same addressing plan (Example WAN1 192.168.10.1 and WAN2 192.168.10.1) and I think that this will not work.
    Greetings
    Franck
