Remote Access VPN: IKE_AUTH response 1 [ N(AUTH_FAILED) ]
adsw
adsw Posts: 3  Freshman Member
Hello all,
I replaced my Zyxel ZyWALL USG110 with a Zyxel USG FLEX 200H. I configured the Remote Access VPN on the new gateway and setup a IKEv2 profile on an iPhone with iOS 18.x, using the built-in VPN client. I also installed the required self-signed certificate, which I had to manually trust.
When I enable VPN on the iPhone, the IKE_SA_INIT phase is passed without errors, but the IKE_AUTH phase ends with the error message IKE_AUTH response 1 [ N(AUTH_FAILED) ]. It seems that the iOS VPN client is not sending a certificate request and so the authentication fails. With my old gateway and a profile setup under iOS 17.x, everything worked fine. The error only occurred after creating a new profile under iOS 18.x.
I sent a request to the Zyxel support about this and they told me that this seems to be a bug in iOS 18.x. I found information about aHave any of you encountered the same issue and perhaps found a solution that doesn't end in waiting for a bug fix?
Thanks, adsw
  • Zyxel_Kay
    Zyxel_Kay Posts: 1,279  Zyxel Employee
    Hi @adsw
    It appears that iOS 18 introduced changes to the VPN Phase 1 and Phase 2 parameters for its native VPN client. We recommend adjusting the Encryption and Authentication settings on your VPN configuration to align with these updates.
    For step-by-step guidance, please refer to this post on our Community:
    Kay
  • adsw
    Hello Zyxel_Jeff,
    Thanks for the tip and the links, but I have already followed resp. tried these instructions, unfortunately without success. The error message remains the same. Changing the proposals for IKE_SA_INIT (Phase 1) and IKE_AUTH (Phase 2) leads to the same error as before.
    I am at a loss, because the same settings worked fine with the old gateway. The only explanation I have at the moment would be the iOS bug mentioned earlier.
    Best,
    adsw
  • Zyxel_Kay
    Hi @adsw
    Have you tried manually adding the IKEv2 VPN profile? This method might help resolve your issue. You can follow the step-by-step guide in this article:
    How do I manually add an IKEv2 VPN profile on an iPhone for an IKEv2 VPN connection? — Zyxel Community
    Let me know if this works for you!
    Kay
  • adsw
    Hello Zyxel_Kay,
    Thank you for your answer.
    Yes, I tried it to add the profile manually. Server and Remote ID = DDNS server, User Name, Password set and also tried to set Local ID = User Name. Certificate exported and installed and manually trusted in settings on iPhone.
    Long story short. Unfortunately, it doesn't help. But thank you for the tip.
