Zywall USG Flex 200H Email Daily Report not working
Hello
Our Flex 200H doesn't send daily email reports!
Also 'Send Report Now' doesn't work!
In System\Notification the setting there are correct because test e-mails are working perfectly.
So why not the daily e-mail reporting…?
Firmware is up-to-date wirth V1.30(ABWV.1)
Thanks for your help!
Dieter
I found the issue: IP reputation filter has blocked my provider's IP address. Unfortunately, all these security packs coming with new Flex firewalls can drive you crazy…
Are you sending to your mail server?
My Daily Report works here to my mail server using port 25 TLS and STARTTLS
Hi Peter
No I'm using my provider's mail server. But now I tried my own mail server, and yes, it works!!
So this must be an issue on my provider's side. Anyway, the ZyWall mails are normal plain HTML mails.
And even no NDR's are coming back.0 -
- 601 USG FLEX H Series
- 480 News and Release
