Source NAT through vpn tunnels
Let's say we have three sites:
Site A (USG Flex 50) - Policy based vpn - Site B (USG Flex 200) - Policy based vpn - site C (other device, managed by others)
Note: between A and B it's simple routing, hosts keep their IP.
Between B and C it's different: all B lan address reach C site SNATted (in B-C vpn policy) to a single fake address (FakeB). C site is a /32, and knows only that single fake address as remote policy.
Another note: C is only meant to be reached.
Between B-C things work.
Now there is a need: an host of A should reach C.
This would require:
-on A, policy route with source A client - destination site C - next hop tunnel A-B
-on B, policy route with source vpn tunnel - A client - destination site C - next hop tunnel B-C
This would be ok if all was simply routed. But A client must go to C SNATed to FakeB.
I did some test and it doesn't seem possible. Or perhaps I missed something.
-VPN policy C-B, in its SNAT section, already defines SNAT of RealB to FakeB. So, it cannot deal with an A-lan object.
-In policy routes (A-B and B-C), when you select a tunnel as next-hop, "SNAT-to" setting is not present.
Now I think I should convert vpn A-B to VTI: since VTI appears as "interface", it leaves "SNAT-to" available.
Is it the right way?
Best Answers
I try to summarize working setup, should it be needed by someone during a search.
Site A (USG Flex 50) - Policy based S2S vpn - Site B (USG Flex 200) - Policy based S2S vpn - site C (other device).
Site A and site B need to go to C, SNATted to specific IP, "FakeB".
On A site: no special config
Between A and B, two phase 2 policies over the same phase1.
Tunnel AB (policy LAN A - LAN B)
Tunnel A2B2 (policy LAN A - FakeB)
On B, BC vpn of type "tunnel", with local - remote policy Fake B - LAN C, and related Tunnel VT0
(thanks to zyman2008 for the suggestion to set tunnel BC local-remote policy with CLI)
On B, two policy routes (one for local, one for A)
From LAN B - to LAN C - next hop VTI0 - SNAT to FakeB
From A2B2 (or from AB) tunnel - to LAN C - next hop VTI0 - SNAT to FakeB
Sorry, I now find that I wrote it wrong but I cannot edit message.
Additional A-B Tunnel policy has LAN C, not FAKE B.
FAKE BLAN C)0
Hi @valerio_vanni,
Since policy based VPN of Zyxel firewall only allow one SNAT rule for outbound(B to C).
I think may be try another way,
1.Create route-based VPN Connection rule for B - C, then you get a VTI interface to C.
But you need using CLI to modify the local/remote policy from any to the address object B, C
crypto map VPNConnectionName
local-policy any → local-policy address-objectB
remote-policy any → remote-policy address-objectC
2.Create policy route rule for B to C, SNAT to fakeB.
3.Create policy route rule for A to C, SNAT to fakeB.
As I said, site C is out of control and that VPN is "untouchable" on that side.
Or what you suggest in point 1 would make C side "happy" only setting with CLI local and remote policies? IP of VTI would play no role, right?
Does VTI likes this change from CLI? Is it supported or there's some risk that some firmware upgrade reverts back these values?
My idea would be of a VTI on A-B.
So
B-C vpn policy would keep on SNATting B Lan (like now)
Policy rule on A firewall (from A lan to VTI) would SNAT A client to FakeB;
At the next step, policy route on B firewall (from VTI to B-C tunnel) doesnt' need to SNAT because the source is already FakeB.
But I like your idea, if it doesn't require changes on C.
About mine, I'm worried about double wan. In VTI documentation I read that (in bold what I noticed):
Restrictions for IPSec Virtual Tunnel Interface•IPv4 traffic only•IPSec tunnel mode only.A shared keyword must not be configured when using tunnel mode.•With a VTI VPN you do not add local or remote LANs to your VPN configuration.•For a VTI VPN you should only have one local and one remote WAN.•A dynamic peer is not supported•The IPSec VTI is limited to IP unicast and multicast traffic only.A shared key must not be configured? Why?
Only single WAN? A-B, now, has double (single on A, double on B). Should I, then, make 2 VPN gateways (A-Bwan1, A-Bwan2), 2 VPN connections and 2 VTI (and finally trunking the latest)?
I decided to try your way.
This works, vpn is up and vti too.
Even this works: in routing traces I see three steps
-real B LAN → C host - from vpn id 0 to id 0 - incoming interface x - outgoing VTI0
-fake B LAN → C host - from vpn id 0 to id 0 - incoming interface x - outgoing VTI0
-C host → real B LAN - from vpn id 5 to id 0 - incoming interface x - outgoing LAN1
And this doesn't work. I've checked also policy control but it doesn't generate events, it seems a routing issue.
On A firewall, I simply see
-A host → C host - from vpn id 0 to id 2 - incoming interface x - outgoing doll
But nothing comes back.
On B firewall, traffic is received from A site, sent to C, received from C and finally not sent to A.
Routing traces show
-A host → C host - from vpn id 3 to id 0 - incoming interface x - outgoing VTI0
-Fake B LAN → C host - from vpn id 3 to id 0 - incoming interface x - outgoing VTI0
-C host → real A host - from vpn id 5 to id 0 - incoming interface x - outgoing WAN1
Outgoing WAN1… why?
I look at rule and I don't find anything wrong
user: any - incoming: tunnel - A-B - source address: A host - destination address: C host - dscp: any - schedule: none - Service: selected (also tried "any", it doesn't change) - next hop: interface VTI0 - SNAT to fake B
This is a lot to take in.
If site A LAN is 192.168.11.0/24
site B LAN is 192.168.22.0/24
site C LAN is 192.168.33.0/24You have site B 192.168.22.0/24 SNAT site to site to single fake address 192.168.44.1 to get to site C
and now you want site A to go to C as that fake address 192.168.44.1 through B.
is that about right?
Right.
In initial setup, traffic flowed from A to B but then cannot go to C with SNAT.
Zyman2008 suggestion made things better. Now it goes to C with SNAT, it comes back to B but then it runs away on B WAN1 interface instead of going towards tunnel A-B.
Hi @valerio_vanni ,
it goes to C with SNAT, it comes back to B but then it runs away on B WAN1 interface instead of going towards tunnel A-B.Does A and B using policy-based IPSec VPN ? what's the local/remote policy ?
If the local/remote of rule A-B doesn't include subnet C.
Then you need another policy route on B, to enforce the return traffic from C to A go into tunnel A-B.
VPN policy A-B has only A and B LAN1 subnets as local-remote policy.
Just to see if it helped, I had set policy route on B, but it didn't work.
With source VTI0 - dest A-B tunnel, last step went to WAN1, with source B-C tunnel - dest A-B tunnel it went to doll (but nothing to site A).
At that point, my suspect was that A-B tunnel rejected all what was outside its local-remote policy. Even if it was a return of something that had come out from it, and even with a policy.
So I created another phase 2 on same phase 1 between A-B, let's call A2-B2 tunnel.
On A, local-policy = A client - remote policy: C Host.
On B, the opposite.
Then, traffic began to flow.
The last step of trace on B firewall, from
became
-C host → real A host - from vpn id 5 to id 6 - incoming interface x - outgoing doll
id 6 is the new tunnel, A2-B2
Traffic didn't use same tunnel, it went from A to B in A-B tunnel (id 3) and came finally back in A2-B2 tunnel (id6).
Then I changed policy route on A to use A2-B2 as next-hop, and on B to use A2-B2 as source. Just because I like more this way, that both directions use same tunnel :-)
In both cases (same or different tunnel for opposite directions), I didn't need any "return" rule on B.
so this is solved?
Duplicate message, please delete.
- 603 USG FLEX H Series
- 480 News and Release
