EEE / Green Ethernet
Thank you! When using them for Dante (audio over IP) this is crucial to have switched off.
Hi @jensskov
If you require audio over IP, I’d recommend considering a switch model specifically designed for Networked AV scenarios. While your current GS1915 supports IGMP snooping well, the models listed here are tailored for Networked AV use and offer advanced features optimized for this purpose.
Kay
- 441 Beta Program
- 532 USG FLEX H Series
- 333 Security Ideas
- 51 Wireless Ideas
- 293 Service & License
- 461 News and Release
