NWA210AX not working with POE and NETGEAR GS305P
Blise610
Blise610 Posts: 3 image  Freshman Member
What do i do wrong. The AP won't work with POE+ with the NETGEAR GS305P.
No lights are blinking and the switch says POE fault.
I already did a reset but still not working. It does work with a power adapter but not with POE+
Please help/advice.
Greetings
Victor
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,320 image  Zyxel Employee
    Hi @Blise610 ,
    From your test, it appears the NWA210AX works well with both PoE and power adapter. Since we're not familiar with Netgear switches, we recommend checking the user guide to ensure proper PoE+ configuration or contacting Netgear for additional support.
    Zyxel_Judy
    Untitled Image
  • Zyxel_Judy
    edited December 2024
    Hi @Blise610 ,
    To troubleshoot the NWA210AX PoE connection, please try these steps:
    • Connect the NWA210AX to a different PoE injector or switch to determine if the issue is with the AP or the NETGEAR GS305P's PoE+ function
    • Connect the NWA210AX to a different PoE+ port on your NETGEAR GS305P to eliminate the possibility of a faulty port 1
    • Verify that your chosen port is correctly configured for PoE+ operation
    Zyxel_Judy
    Untitled Image
  • Blise610
    No I did all that. I think the Netgear is nog good enough. Is that possible?
  • Zyxel_Judy
    Hi @Blise610 ,
    These troubleshooting steps will help identify the source of the issue. Please try them and share your results so we can provide better targeted support.
    Zyxel_Judy
    Untitled Image
  • Blise610
    Yes i tried on another poe injector and the ap worked. A different port on the netgear doesn't work. All ports are poe. So on the netgear poe doesn't work.
  • Zyxel_Judy
    Hi @Blise610 ,
    Zyxel_Judy
    Untitled Image
  • mMontana
    mMontana Posts: 1,468 image  Guru Member
    AFAIK PoE nowadays is an umbrella term for a bazillion of standards, starting from 802.3af and ending with 802.3bt and several alternatives/modes for all types.
    IMVHO switches and AP specs should be reviewed thorougly including the (possible, not granted) backward compatibility.
