[USG FLEX 100] VPN doesn't work
Brandix
Brandix Posts: 8 image  Freshman Member
Hello, the VPN stop working and I cannot fix it. Can someone help me?
This is the history log:
32
2024-12-26 12:13:43
info
IKE
Tunnel [RemoteAccess_L2TP_Wiz:L2TP_VPN_Connection:0x1b4cb4f2] is disconnected
192.168.1.254:500
 84.78.243.245:23355
IKE_LOG
33
2024-12-26 12:13:42
info
IKE
Dynamic Tunnel [RemoteAccess_L2TP_Wiz:L2TP_VPN_Connection:0xaa2df82c] rekeyed successfully
192.168.1.254:4500
 84.78.243.245:4500
IKE_LOG
34
2024-12-26 12:13:42
info
IKE
[ESP 3des-cbc|hmac-sha1-96][SPI 0xe9ac2823|0xaa2df82c][Lifetime 3620]
192.168.1.254:4500
 84.78.243.245:4500
IKE_LOG
35
2024-12-26 12:13:41
notice
Security Policy Control
Match default rule, DROP
 185.156.73.53:44835
192.168.1.254:4489
ACCESS BLOCK
36
2024-12-26 12:13:39
notice
192.168.1.1:49021
192.168.1.254:137
ACCESS BLOCK
37
2024-12-26 12:13:39
info
IKE
Tunnel [RemoteAccess_L2TP_Wiz:L2TP_VPN_Connection:0x7fd1104a] is disconnected
192.168.1.254:500
 84.78.243.245:23355
IKE_LOG
38
2024-12-26 12:13:38
notice
192.168.1.1:48639
192.168.1.254:137
ACCESS BLOCK
39
2024-12-26 12:13:38
info
IKE
Dynamic Tunnel [RemoteAccess_L2TP_Wiz:L2TP_VPN_Connection:0x1b4cb4f2] rekeyed successfully
192.168.1.254:4500
 84.78.243.245:4500
IKE_LOG
40
2024-12-26 12:13:38
info
IKE
[ESP 3des-cbc|hmac-sha1-96][SPI 0x7b60ea8c|0x1b4cb4f2][Lifetime 3620]
192.168.1.254:4500
 84.78.243.245:4500
IKE_LOG
41
2024-12-26 12:13:38
info
IKE
Send:[HASH][DEL] [count=6]
192.168.1.254:4500
 84.78.243.245:4500
IKE_LOG
42
2024-12-26 12:13:36
info
IKE
Tunnel [RemoteAccess_L2TP_Wiz:L2TP_VPN_Connection:0x136f7810] is disconnected
192.168.1.254:500
 84.78.243.245:23355
IKE_LOG
43
2024-12-26 12:13:36
info
IKE
The cookie pair is : 0x21cccad12765a1c4 / 0x52a69420f4372655 [count=3]
192.168.1.254:500
 84.78.243.245:23355
IKE_LOG
44
2024-12-26 12:13:35
info
IKE
Dynamic Tunnel [RemoteAccess_L2TP_Wiz:L2TP_VPN_Connection:0x7fd1104a] rekeyed successfully
192.168.1.254:4500
 84.78.243.245:4500
IKE_LOG
45
2024-12-26 12:13:35
info
IKE
[ESP 3des-cbc|hmac-sha1-96][SPI 0x398ea70d|0x7fd1104a][Lifetime 3620]
192.168.1.254:4500
 84.78.243.245:4500
IKE_LOG
46
2024-12-26 12:13:35
info
IKE
Recv:[HASH][DEL] [count=3]
 84.78.243.245:4500
192.168.1.254:4500
IKE_LOG
47
2024-12-26 12:13:35
info
IKE
Dynamic Tunnel [RemoteAccess_L2TP_Wiz:L2TP_VPN_Connection:0x136f7810] built successfully
192.168.1.254:4500
 84.78.243.245:4500
IKE_LOG
48
2024-12-26 12:13:35
info
IKE
[ESP 3des-cbc|hmac-sha1-96][SPI 0xbf4c8889|0x136f7810][Lifetime 3620]
192.168.1.254:4500
 84.78.243.245:4500
IKE_LOG
49
2024-12-26 12:13:35
info
IKE
[Policy: ipv4(udp:1701,92.56.48.166)-ipv4(udp:1701,192.168.42.53)] [count=4]
192.168.1.254:4500
 84.78.243.245:4500
IKE_LOG
50
2024-12-26 12:13:35
info
IKE
[Responder:192.168.1.254][Initiator:84.78.243.245] [count=4]
192.168.1.254:4500
 84.78.243.245:4500
IKE_LOG
51
2024-12-26 12:13:35
info
IKE
Recv:[HASH] [count=4]
 84.78.243.245:4500
192.168.1.254:4500
IKE_LOG
52
2024-12-26 12:13:34
info
IKE
Send:[HASH][SA][NONCE][ID][ID][PRV][PRV] [count=4]
192.168.1.254:4500
 84.78.243.245:4500
IKE_LOG
53
2024-12-26 12:13:34
info
IKE
Recv TSi: ipv4(udp:1701,192.168.42.53), TSr: ipv4(udp:1701,92.56.48.166). [count=4]
 84.78.243.245:4500
192.168.1.254:4500
IKE_LOG
54
2024-12-26 12:13:34
info
IKE
Recv IPSec sa: SA([0] protocol = ESP (3), spi_len = 4, spi = 0x00000000, AES CBC key len = 256, HMAC-SHA1-96, No ESN, AES CBC key len = 128, 3DES, DES, NULL; ). [count=4]
 84.78.243.245:4500
192.168.1.254:4500
IKE_LOG
55
2024-12-26 12:13:34
info
IKE
Recv:[HASH][SA][NONCE][ID][ID][PRV][PRV] [count=4]
 84.78.243.245:4500
192.168.1.254:4500
IKE_LOG
56
2024-12-26 12:13:34
info
IKE
Phase 1 IKE SA process done
192.168.1.254:4500
 84.78.243.245:4500
IKE_LOG
57
2024-12-26 12:13:34
info
IKE
Send:[ID][HASH]
192.168.1.254:4500
 84.78.243.245:4500
IKE_LOG
58
2024-12-26 12:13:34
info
IKE
The cookie pair is : 0x21cccad12765a1c4 / 0x52a69420f4372655 [count=28]
192.168.1.254:4500
 84.78.243.245:4500
IKE_LOG
59
2024-12-26 12:13:34
info
IKE
Recv:[ID][HASH]
 84.78.243.245:4500
192.168.1.254:4500
IKE_LOG
60
2024-12-26 12:13:34
info
IKE
The cookie pair is : 0x52a69420f4372655 / 0x21cccad12765a1c4 [count=12]
 84.78.243.245:4500
192.168.1.254:4500
IKE_LOG
61
2024-12-26 12:13:34
info
IKE
Send:[KE][NONCE][PRV][PRV]
192.168.1.254:500
 84.78.243.245:23360
IKE_LOG
62
2024-12-26 12:13:34
info
IKE
Recv:[KE][NONCE][PRV][PRV]
 84.78.243.245:23360
192.168.1.254:500
IKE_LOG
63
2024-12-26 12:13:34
info
IKE
Send:[SA][VID][VID][VID][VID][VID][VID][VID][VID][VID][VID]
192.168.1.254:500
 84.78.243.245:23360
IKE_LOG
64
2024-12-26 12:13:34
info
IKE
The cookie pair is : 0x21cccad12765a1c4 / 0x52a69420f4372655 [count=2]
192.168.1.254:500
 84.78.243.245:23360
IKE_LOG
65
2024-12-26 12:13:34
info
IKE
Recv IKE sa: SA([0] protocol = IKE (1), AES CBC key len = 256, HMAC-SHA1 PRF, HMAC-SHA1-96, 384 bit ECP, AES CBC key len = 128, 256 bit ECP, 2048 bit MODP, 3DES, 1024 bit MODP; ).
 84.78.243.245:23360
192.168.1.254:500
IKE_LOG
66
2024-12-26 12:13:34
info
IKE
Recv:[SA][VID][VID][VID][VID][VID][VID][VID][VID]
 84.78.243.245:23360
192.168.1.254:500
IKE_LOG
67
2024-12-26 12:13:34
info
IKE
The cookie pair is : 0x52a69420f4372655 / 0x21cccad12765a1c4 [count=2]
 84.78.243.245:23360
192.168.1.254:500
IKE_LOG
68
2024-12-26 12:13:34
info
IKE
Recv Main Mode request from [84.78.243.245]
 84.78.243.245:23360
192.168.1.254:500
IKE_LOG
69
2024-12-26 12:13:34
info
IKE
The cookie pair is : 0x21cccad12765a1c4 / 0x0000000000000000
 84.78.243.245:23360
192.168.1.254:500
IKE_LOG
  • JC____37
    JC____37 Posts: 2 image  Freshman Member
    We have the same issue in my company since this monday, we've tried to replace the firewall with a new one but we weren't be able to fix it too. 😶
    Regards.
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,611 image  Zyxel Employee
    edited December 2024
    Hi @Brandix,
    It is more likely the VPN client has some problem that cannot connect to the VPN. Could you share the error message the VPN client displayed?
    Also, please help provide the device configuration and the detailed topology between the firewall and the VPN client so we can further check.
    Zyxel Melen
  • Zyxel_Melen
    Hi @JC____37,
    Please describe more details so we can help you. Like the symptom, device's logs and configuration, client's logs or error message, and the detailed topology between the firewall and the VPN client.
    Zyxel Melen
  • JC____37
    The problem has been finally solved on our side. Someone desactivated "L2TP feature" inside the "VPN site by site" nebula menu.
    Thks for your reply, regards.
  • Zyxel_Melen
    Hi @JC____37,
    Thanks for updating. That's terrifying. I suggest you edit the admin privilege to read-only for that account to avoid this issue happening again.
    Zyxel Melen
