USG flex 100 import a public certificate
Fabio
Fabio Posts: 31 image  Freshman Member
First Comment Sixth Anniversary
I am trying to import a public certificate, which is used by public CA.
But if i try .pem the answer there is no a certificate request
If i try a PKCS12, the answer is; format not supported
firmware is the last
V5.39(ABUH.1) / 2024-11-16 03:58:40
How i can import the cerificate.
Best Answers
  • Fabio
    I understand that Zywall cannot import any STANDARD .pfx certificates, but only the certificates built with some selected software, and with a selected procedure
    .I will try to convert it.
  • Fabio
    sorry I make a mistake now it works.
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,244 image  Zyxel Employee
    Oh, I see. Thanks for updating! @Fabio
    Zyxel Melen
