USG flex 100 import a public certificate
I am trying to import a public certificate, which is used by public CA.
But if i try .pem the answer there is no a certificate request
If i try a PKCS12, the answer is; format not supported
firmware is the last
V5.39(ABUH.1) / 2024-11-16 03:58:40
How i can import the cerificate.
Best Answers
I understand that Zywall cannot import any STANDARD .pfx certificates, but only the certificates built with some selected software, and with a selected procedure
.I will try to convert it.
sorry I make a mistake now it works.
You need to combined the .key and .crt to be a .pfx using the windows certutil tool like
certutil –MergePFX zyxel-router1.ddns.net.crt cert.pfxThe name of .key and .crt must be the same
I have done it, and the pfx (password protected) can be imported in widows, but the USG100 say the format is not supported
ok try openSSL
Win32/Win64 OpenSSL Installer for Windows - Shining Light Productions
windows command like
openssl pkcs12 -export -out zyxel-router1.ddns.net.pfx -inkey zyxel-router1.ddns.net.key -in zyxel-router1.ddns.net.crt
Hi @Fabio,
Please reference these FAQs first.
Unable to import PFX file with intermediate certificates — Zyxel Community
How to import the certificate for local GUI used — Zyxel Community
Zyxel Melen0 -
I try according your suggestions but it does not work
c:openssl pkcs12 -export -out etereru2.pfx -inkey etereru2.key -in etereru2.crt
errno: -17011
errmsg: PKI certificate type is not supportedwindows import it correctly.
Hi @Fabio,
Would you be willing to send us your certificate so we can help check this issue? If so, please send me a forum message with the file.
Zyxel Melen0 -
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
