USG60W - connect from IPSEC connected site to Web GUI
ondrej_gorcik
ondrej_gorcik Posts: 2 image  Freshman Member
I am trying to solve problem with connection to router administration. I have 2 sites succesfully connected thru IPSec. I am connected to site A with SSL VPN. Site A is connected to site B thru IPSEC. I can access devices in Site B network. But I cannot access router administration website.
Log from site A:
Log from site B:
From outside on public IP it works normally. Rules seems to be ok. No restrictions for web access:
Please any ideas what could be wrong?
Thank to all of you
Ondrej
    PeterUK Posts: 4,418 image  Guru Member
    edited January 2025 Answer ✓
    On site B what is the remote policy of the VPN tunnel?
    If not 172.16.220.0/24? site B will not know to send reply down tunnel from what I can tell
    see if a routing rule on B with
    incoming ZyWALL
    Destination address 172.16.220.0/24?
    next hop VPN Tunnel
    incoming ZyWALL
    next hop VPN Tunnel
  • ondrej_gorcik
    Thats exactly what was missing there. I had only Policy route for the network not the second route for ZyWALL.
    Thanks for your help.
    O.
