Block internet radio
@THM
Can I know are the Radios application or working on the website?
If the Radios execute on the web site, you can Go to Content Filter> Create the profile to block domain mane.
However, the Radios need to be blocked via APP Patrol if it is working as application.
Charlie
Yes radios execute on web sites. For example : http://www.radio-en-ligne.fr/ or http://www.webmaster-gratuit.com/radio/
I know that : Content Filter> Create the profile to block domain, but it's a set of sélections. So there are a lot of them…
@THM
Can I know you only want to block some channel (Radio) from these two website not whole website?
Charlie0 -
I want to block every and each radio on every and each website
I will try ASAP.
Thank you very much!
Hi this is the thing that i have encountered my workaround it is go to settings on your phone browser. then you go to the notification section of the browser settings and turn off the notification of the website that provides the radio station.
- 441 Beta Program
- 293 Service & License
