LAN interface Failover
another_user
another_user Posts: 16 image  Freshman Member
Hello guys
I have an USG 1100 with an physic interface (internal) like 172.16.0.254 with a policy route that send all traffic to 172.16.0.1(another router) for all destination network 172.16.0.0/16
I want add a failover interface (172.16.0.253) that route a secondary router (172.16.0.2) when primary is down.
I saw failover (TRUNK) working only WAN interface, how can I implement it on internal interfaces too?
Should i add only a lower policy route with the secondary rout with connectivity check on primary?
many thanks
    PeterUK Posts: 4,182 image  Guru Member
    Some problems with your placeholders IP you say you have if LAN is 172.16.0.254/16 how will it get to 172.16.0.1 on the WAN interface?
    In a normal simple Failover you have a LAN 192.168.0.1/24 and two WAN interfaces ideally real WAN IPs or say WAN1 10.1.1.2/24 gateway 10.1.1.1 and WAN2 10.2.2.2/24 gateway 10.2.2.1
    you then add two routing rules
    top is
    incoming LAN
    next hop WAN1
    ping check
    bottem is
    incoming LAN
    next hop WAN2
  • another_user
    My mistake, it is 172.16.0.0/12 (not /16) therefore from 172.16.0.0 to 172.16.31.255, it is therefore
     not a WAN interface but always a LAN (LAN2), I deduce in any case that your procedure does not
    change and is also functional with LANs.
    Can you say more on what your goal is? maybe I misunderstood?
  • another_user
    I want redundancy in case the interface (Port 5) connecting an external router (172.16.0.1) goes down, and automatically starts a connection via Port 6 with a second router (172.16.0.2).The 2 routers have fiber connections on different routes.
  • valerio_vanni
    valerio_vanni Posts: 157 image  Master Member
    5 Answers First Comment Friend Collector Third Anniversary
    Why do you use these two routers on LAN side, instead of WAN1 and WAN2?
    edited January 3
    I'm still unsure of the setup does the USG 1100 do anything? It seems like clients are not even going to its gateway? Is that about right? In which cause the USG 1100 can't do anything because clients are going to another routers gateway....
    can you not have real WAN IP's? why only 172.16.0.1 to one and 172.16.0.2 to the other? can they not be different subnets?
    edited January 3
    what I think will work is my fail over idea on a switch
    vote for it
    Fail over without NAT — Zyxel Community
    The idea on how it works is you setup both gateways as 172.16.0.1 on your two routers
    So that you have switch management VLAN 100 untag one cable from port 1 to primary router then this is the tricky bit you have another cable from primary router to port 2 of the switch in untag VLAN200 and the secondary router to port 3 on VLAN200 of switch with your clients on VLAN 200 which would normally cause problems because two same gateways only the fail over idea on a switch comes in to play that you make a policy rule to discard the packet when ping check fails for ARP on port 2 and a policy rule to discard the packet low Weight for ARP port 3 and a policy rule high Weight to No change enable rule when ping check fails for ARP on port 3
    You might also need a policy rule to discard the packet for ARP of the source MAC of switch on port 2
    This then toggles between gateways without conflict
  • another_user
    the existence of a WAN network dictates that it be
    1) NAT
    2) towards public IPs
    In my case they go to a MAN with various subnets with private IP classes (172.16.1.0/24-172.16.2.0/24....172.16.x.0/24)
    I can't use WAN interfaces, but if I don't use WANs failover isn't usable.
  • valerio_vanni
    2: is not true at all, you can have private classes on WAN interfaces
    1: by default LAN to WAN is set to NAT, but you could also disable it
    So you have some network that you reach by WAN1 and WAN2 and others by LAN? Or in WAN1 and WAN2 interfaces there is no connection?
