Nebula SD-WAN home office routers
Best Answers
Hi @brischt
Currently the USG20W-VPN doesn’t support Orchestrator.
I think the VPN50 is a proper model if what you need is to central management all the Gateway devices from Nebula Orchestrator.
What you can benefit from Orchestrator/VPN50 is not only to manage those gateways centrally but also to optimize the network quality between your main site and the remote sites with SDWAN feature. Even more, you can use the LTE connection on the VPN50 as a secondary link to achieve WAN load sharing, failover and those only SDWAN supported features to improve your network reliability.
However, if you only deploy VPN100 in your main site. The “Client AutoVPN” feature allows remote users to access your main site network by using the native operating system VPN utility.
5 -
Hi @brischt
Yes, this is doable. You can add the Non-SD-WAN Gateways onto the Orchestrator, see the screenshot below:
The wizard will guide you to add the Non-SD-WAN gateway step by step and generate the script/configurations (currently the Orchestrator supports Zyxel and Cisco script/configuration) for your reference. Afterward, you'll be able to refer to the generated script and configure your own VPN Gateway manually.
5
Hi @brischt
5 -
Hi @brischt
Here it is the example of "Client AutoVPN" feature:
1. Configure your "Client AutoVPN"
2. After setting up the Client AutoVPN, the specified user will receive a system mail which guides the mail receiver about how to create the VPN tunnel "without" using any 3rd party software.
Thank you, Zyxel_Vic!One other question: Can I use the VPN firewalls in Nebula SD-Mode and still establish VPN connections with other IPSec gateways? (With manual configuration, of course) That way we could gradually replace the soho routers with VPN50 appliances.Thanks!0
Hi @brischt
5 -
Thanks, Zyxel_Vic!Zyxel_Vic said:Hi @brischt
I received my first VPN100 unit in one of my main offices and set it up manually. Works like a charm so far. Now I wanted to try to use Orchestrator and have added my device. However, I do not fully understand how I can assign subnets to my sites. Out of historic reasons, we use 10.0.0.0/24 for the first main office, 10.0.2.0/24 for the second main office, and each (permanently connected) home office worker also gets his own subnet, e.g. 10.0.5.0/24. How does this translate into Orchestrator zones?
Thanks,
brischt
- 441 Beta Program
- 292 Service & License
