Zyxel Flex 500 Fail over
In dual wan setup, if the trunk is "active" and "active, the failover doesnt seem to work. However, if its setup as "Active" and "Passive", failover works flawlessly.
Does failover only work in "active" and "passive" setup?
Hi @HyungKim0105,
Failover needs one interface to be a passive interface. The firewall uses two wan interface if both interfaces are active, and bases on the "Load Balancing Algorithm" you set to send traffic.
For more details, please reference our user's guide P411.
Zyxel Melen0
Testing here with a VPN300 with Ge4 and Ge7 both active works fine the trunk fail over only happens when the interface uplink goes down to either port for the other port to take over.
I did a routeing rule
incoming LAN
next hop TrunkProblem is if the interface don't go down it thinks it still alive so on one of the interface you enable Connectivity Check
Hi @HyungKim0105,
Zyxel Melen0
- 441 Beta Program
- 292 Service & License
