samsung51 zonder wpa 3 op modem aanluiten
Bart1958
Bart1958 Posts: 1 image  Freshman Member
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,669 image  Zyxel Employee
    Hi @Bart1958,
    This seems like your AP and modem use the same SSID profile name. In the scenario, it is possible that you connect to the modem in some cases, like the current signal strength.
    If your purpose is to connect to the AP, you may consider changing the SSID profile name to ensure you connect to the AP.
    Zyxel Melen
  • Zyxel_Melen
    Hi @Bart1958,
    Zyxel Melen
