Connect USG Flex 200 to zywall 110
Hi there,
i`m not a pro but i have to connect two Firewalls via WAN Ports. Setup is as follow:
USG Flex 200
WAN 1 - Connection to World (ETH to ISP)
WAN 2 - 192.168.10.1 - 255.255.255.252 - gw 192.168.10.2 (to zywall 110)
LAN 1 - 192.168.178.0/24
Routing set for Incoming any - source any - Destination 10.1.1.0/24 - next hop WAN 2 no nat
Zywall 110WAN 1 - connection to the world (PPP to ISP)WAN 2 - 192.168.10.2 - 255.255.255.252 - gw 192.168.10.1 (to usg flex 200)LAN 1 - 10.1.1.0/24Routing set for Incoming any - source any - Destination 192.168.178.0/24 - next hop WAN 2 no natBoth firewalls are connected via eth directly. they are in different rooms and support different working units. now i need to connect from any LAN to any LAN and i failed :-/The usg Flex can ping can ping their own interface AND the remote (192.168.10.1).the zywall 110 can ping their own interface and NOT the remote (192.168.10.2).IMHO what i did should be enough but as far as the result said it looks like not. Does you guys see anything i`m doing wrong or messed up?Thanks a lot for helping.All Replies
hi @jkocovski
your setup looks like this: Internet > Zywall 110 > USG Flex 200
USG Flex 200 will block all incoming traffic on WAN port, it will also not respond to a ping.
Might be best to replace the Zywall 110 with the USG Flex 200 and use a layer 3 switch instead of another firewall.
then Site-2-Site VPN would be the way to go.
Maybe you're able to establish a VPN-connection on WAN2 of the USG Flex 200 to the Zywall 110.
- 429 Beta Program
- 2.6K Nebula
- 163 Nebula Ideas
- 6K Security
- 350 USG FLEX H Series
- 291 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 6.6K Consumer Product
- 261 Service & License
- 407 News and Release
- 87 Security Advisories
- 3.8K FAQ
- 82 Security Highlight
