GS1900-24HP VLAN PORT SETTINGS - (BROWSER ISSUE )
kthackwray
kthackwray Posts: 1 image  Freshman Member
Hi there
Trying to set up a port to use VLAN 1 as the untagged Default Vlan and pass VLAN 100 as tagged frames (trunk port )
Browser has missuing "TEXT " next to the buttons - see below and I just need to know what the labels / test for each button is so that I can configure it correctly
I know the browser issue is fixed in later relaeses but have the same issue on the firmware upgrade page see second page below ( and when looking at how to upgrade the firmware I see a lot of posts of issues upgrading these swithches etc. so happy to stay on the old firmware as long as it works )
  • Zyxel_Kay
    edited January 2025 Answer ✓
    Hi @kthackwray
    Thank you for reaching out to the Zyxel Community!
    We recommend upgrading your GS1900-24HP to the latest firmware version, as it includes several enhancements and fixes that can improve the overall experience and resolve known issues. You can download the latest firmware here:
    Latest firmware: 2.70(AAHM.3)C0
    Regarding the browser issue with missing text labels:
    • Please try using Internet Explorer since the running firmware is too old and doesn't support other browsers.
    Kay
  • Zyxel_Kay
    Hi @kthackwray
    Kay
