setting up NWA55AXE
I have a Zyxel Router NR5307 and an Accespoint NWA55AXE.
I want to use the AP as an extender for the NR5307.
With the same login credentials as the NR5307. But i cannot get this to work.
I know it is my mistake but can somebody please explain to me in plain english how i can do this.
thnx in advance
Hi @burnt
Thank you for reaching out!
It sounds like you'd like to create a roaming scenario where your devices can seamlessly switch between your NR5307 router and the NWA55AXE access point. If that's the case, here's how you can achieve it:
- Connect the Access Point:Use an Ethernet cable to connect your NWA55AXE to your NR5307 router. This ensures a stable connection between the two devices.
- Match Wireless Settings:
- Set the SSID (WiFi network name), password, and security mode (WPA2/WPA3) on the NWA55AXE to match the settings on your NR5307.
- This allows your devices to automatically switch between the two without needing to reconnect manually.
Kay
Hi @burnt
Kay
- 601 USG FLEX H Series
- 480 News and Release
