Maximize Throughput on USG40
I have a USG40. I'm wanting to know how to configure this device to get maximum throughput on it.
Some background:
ISP is Comcast with a 250mbps down and 20 up.
GB network switch and all CAT6 cabling
When I run speed tests from various websites w/the USG40 in place, I get speeds that range from 100 down/5 up to 200 down and 15 up.
When I connect a computer directly to the Comcast modem - no router in place, I can test on 10 different sites, and I'll always get 250 down, 280 down, even up to 320 down and 20-22 up.
That tells me there is some overhead w/the router.
Some specs on the router:
Firmware version 4.33 (latest release)
Session control is set to 0 (zero)
I have active licenses for IDP Signatures, AV, anti-spam, content filter, ADP, and security policy control. However, I am only using AV and content filter.
I have disabled the AV and content filter, but that doesn't speed up anything, so they are re-enabled.
What other settings can I adjust to get better throughput on this device? The client is ready to upgrade to a 1000mbps down speed. I know this router won't let them have that top speed or even come close to it.
Thanks in advance for your reply.
Some background:
@steve02a
The throughput will be affect when you enable the Firewall or UTM profiles.
Since the firewall need to check and analyze each packet, therefore, it will consume numerous performance.
On my lab, when disable firewall, the throughput is 210Mbp/s. When enable firewall, the throughput will be 155Mbp/s. However, the statistic of throughput may be different by test machine or test process or test environment.
Charlie
You could disable the ADP to speed things up.
Zyxel_Charlie said:@steve02a
Charlie
How do you disable the firewall? Not that I would - what's the purpose of having a router/firewall if you don't use the firewall - but I am curious to know how to disable it so I can do some testing.0 -
@steve02a
As I mentioned, the test with "disable firewall" which means connect to internet directly without firewall. Otherwise, when enable firewall feature, the throughput will be affect on every UTM devices.
The way to disable firewall.
You can go to Configuration>Security Policy>Policy Control
Charlie0
- 441 Beta Program
- 533 USG FLEX H Series
- 334 Security Ideas
- 51 Wireless Ideas
- 295 Service & License
- 461 News and Release
