NWA50AX-PRO alterable MACs??
SteveO
SteveO Posts: 1 image  Freshman Member
Hi All,
I have a NWA50AX-PRO. Seems that I have a real 'piece of work' neighbor that is practicing his wifi hacking skills on my AP mentioned. I've been getting loads of deauths.
With this said. I need to understand I I am able to change the mac addresses associated with the ethernet PoE and Macs of each of the WIFIs? If so then how?
If not then I request this as an upgrade improvement as this individual is targeting my mac addresses and not the AP names itself and I really do not want to fork out more money for another AP.
Thanks and regards
SteveO
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,344 image  Zyxel Employee
    It is not possible to change AP's MAC address. For WiFi clients, they can only change the MAC with the option <random MAC address>.
    However, I don't think changing AP's MAC address can let you eliminate your neighbor since he can still find your SSID. I recommend changing the security option to WPA3 and monitoring if this issue happens again.
    Zyxel Melen
  • Zyxel_Melen
    Zyxel Melen
