USG FLEX 50 log format for a Synology log server
Hi !
I'm trying to send my USG FLEX 50 logs to a Synology log server but I'm struggling with the format.
Both "Syslog" and "CEF/Syslog" appear to not be supported by Synology, as values are not mapped properly.
There is, in the Synology log server settings, an option for a custom format using a pattern parser (for example @STRING:Hostname:@), but I cannot seem to find how to make it work, despite having used pretty much anything I could find in the syslog-ng documentation (linked in the Synology logs docs)
Has someone successfully sent their USG FLEX logs to a Synology NAS in a usable form ?
Thanks.
Hi @segFaultCreat0r, have you tried using another syslog server, like , to see if the logs are being mapped correctly? This could help determine if the issue is specific to Synology's log server.
Also, in another thread, someone mentioned successfully sending logs from a Zyxel ATP firewall to a Synology log server. You might find their configuration helpful:
SYSLOG from ATP to Synology — Zyxel Community0
- 222 Nebula Ideas
- 616 USG FLEX H Series
- 53 Wireless Ideas
- 483 News and Release
