Migration from a Zyxel 110 to a USG 500H
Hi there.
I'm tring to migrate a configuration from Zyxel 110 with v4.73 firmware from 2023 to a USG 500H. That next week will replace old model.
Migration too helps to Zyxel 110 ⇒ USG 500 then will be from USG500 ⇒ USG 500H but in the begining of secound step migration too say this is not a USG 500 config file.
Can anyone hell or i have to configure from scratch.
Best Regards
Alexandre Silva
With H models you have to config from scratch
Ok PeterUK tanks for quick answer.
I will munual configure this.
Best Regards,
Ok Peter.
Is possible to configure USG Flex without Nebula rules?
In the past i connect via SSL VPN connection i can allow a group to access address object.
How can i do same now? How can i create groups?
Implement a policy like USG Flex that user connects only from specific country. And only can manage firewall after connect from vpn or local.
Best Regards
Alexandre Silva
Yes FLEX H can be configured as standalone
I think you need under Clients will use VPN to access Local Networks Only (Split Tunnel)
as for the other thing are you talking about this bit on non H models? the admin service control?
you can lock down access to Flex H by policy control not tested access to FLEX H over VPN but should be possible
Ok Peter i will test it. Some of my clients firewall is behind NAT and sometime is usefull to go to internet operator change NAT rules there.
How to configure without Nebula.
One more question. Portugues internet market is changing and newcomer DIGI operator only work with GNAT. Is it possible to have SSV VPN and IPSEC behind that configurations?
- 415 Beta Program
- 2.4K Nebula
- 151 Nebula Ideas
- 98 Nebula Status and Incidents
- 5.7K Security
- 277 USG FLEX H Series
- 276 Security Ideas
- 1.4K Switch
- 74 Switch Ideas
- 1.1K Wireless
- 42 Wireless Ideas
- 6.4K Consumer Product
- 250 Service & License
- 395 News and Release
- 85 Security Advisories
- 29 Education Center
- 3.6K FAQ
- 74 Security Highlight
