VLAN on USG200
Gaetano
Gaetano Posts: 17  Freshman Member
Hi everyone,I'm using a USG200 firewall to use a VLAN in my case Vlan 20.I configured it on the internal door Lan1 and assigned on the door of my Switch.Everything works if I go to Lan1 from Vlan20, it doesn't work if I go to Vlan20 from Lan1.What's wrong? Thank you
    PeterUK Posts: 3,506  Guru Member
    Likely to do with zones did you given VLAN20 a zone? then you need from LAN1 zone to VLAN20 zone
  • Gaetano
    Yes, I created VLAN 20 on the LAN1 zone, and I need to show the two networks. Currently it is unidirectional
    Ok because you put them on the same zone you need policy rule from LAN1 to LAN1
