Setting up Firewall USG60
Micke_MNO
Micke_MNO Posts: 4 image  Freshman Member
When Im trying to connect to my USG60 it always shows HTTPS with a red text and with a line crossing those letters, port 8443 (https://192.168.0.1:8443/) is used as a default when I have typed in the IP address to my USG60.
I dont know where to sort this, if its a security setting in the firewall or if its a security setting in my W10 (I have just performed a complete reinstall of my home PC).
I have been looking for advises on the internet and other places, but this far I havent seen anything that even touch this topic.
I dont know why the prolem is there or whats causing this phenomen.
If someone have an idea I would be happy to share that idea.
//Micke
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,347 image  Zyxel Employee
    edited January 2025
    Hi Micke,
    This is occurring because your browser doesn't recognize the firewall's security certificate. It is the normal behavior.
    Are you looking to change the WAN access port from 8443 to 443? If so, you can modify this setting in the WWW configuration menu.
    Please be aware that the USG 60 model has reached its EOL status. For optimal performance and support, we recommend exploring our current firewall offerings here:
    https://www.zyxel.com/us/en-us/products/next-gen-firewall
    Zyxel_Judy
    Untitled Image
  • Micke_MNO
    Hi, and thanks for your answer.
    Unfortinally this didnt really answered my concerns.
    What worries me is that because of this red HTTPS with crossing lines I gets recommended at my login attempt to not log in to this unit when its concidered as unsecure, and I need to take other ways when windows tries to prevent my connection.
    I would like to get rid of this red text so I can access my firewall directly.
    I heard someone saying that this phenomen is because of a certificate in my USG60 is faulty or something else which makes it to be obsolete or something.
    Since my first message I have tried to access my USG60 from another computer which gave the same phenomen, so by this I can take out my newly reinstalled PC from this equation.
    //Micke
    PeterUK Posts: 4,446 image  Guru Member
    edited January 2025
    In which case you need a Certificate
    You then need to point you DNS of your DDNS to USG IP
    or you can do a self sign Certificate but you would need to import to windows trusted root Certification authorities
