VLAN on USG200
Hi everyone,I'm using a USG200 firewall to use a VLAN in my case Vlan 20.I configured it on the internal door Lan1 and assigned on the door of my Switch.Everything works if I go to Lan1 from Vlan20, it doesn't work if I go to Vlan20 from Lan1.What's wrong? Thank you
Likely to do with zones did you given VLAN20 a zone? then you need from LAN1 zone to VLAN20 zone
Yes, I created VLAN 20 on the LAN1 zone, and I need to show the two networks. Currently it is unidirectional
Ok because you put them on the same zone you need policy rule from LAN1 to LAN1
I didn't do anything wrong, it was the windows firewall that was blocking everything.thanks anyway
- 431 Beta Program
- 2.6K Nebula
- 170 Nebula Ideas
- 6K Security
- 385 USG FLEX H Series
- 294 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 267 Service & License
- 412 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
