USG and ipsec client vlan
Hi
Can i set up 2 ipsec gw and connections to different lan and vlan?
i have 1 ipsec gw to lan1.
i want to set up ipsec 2 to vlan10
so the client can use ipsec greenbow software, and choose witch connection he want to use.
is that possible?
Regards Tony
Best Answers
Hi @ITBiten
Yes, you can just create 2nd VPN connection on USG and VPN client for VLAN10.
And then establish VPN tunnel which you would like to accessed.
VPN Gateway:
VPN Connections for LAN1 and VLAN.
ZyWALL IPSec VPN Client
5 -
Thank you
Works like a charm.
Hi @ITBiten
VPN Gateway:
5 -
Thank you
Works like a charm.
- 439 Beta Program
- 191 Nebula Ideas
- 6.2K Security
- 469 USG FLEX H Series
- 308 Security Ideas
- 82 Switch Ideas
- 281 Service & License
- 441 News and Release
- 4.3K FAQ
- 93 Security Highlight
