USG Flex 700H Bridge Interface to group individual ports
phayze
As the 2 SFP+ port on Flex 700H is considered individual port and cannot be group together. Can we use the below example to create a bridge to overcome this as the below example is on different platform as Flex 700? Is there any guide or example on Flex 700H platform?
USG FLEX / ATP: Bridge Interface – Zyxel Support Campus EMEA
Hi @phayze,
Please reference the below steps to configure: (I use internal role for example)
- Create the interfaces for SFP ports 13 and 14.
The interfaces after the configuration: - Create the bridge interface for the SFP ports.
Hope it helps.
Zyxel Melen0 - Create the interfaces for SFP ports 13 and 14.
Hi @phayze,
Hope it helps.
does this work also when on each bridge port a single connection to a switch is connected?
- 439 Beta Program
- 2.8K Nebula
- 200 Nebula Ideas
- 6.3K Security
- 500 USG FLEX H Series
- 323 Security Ideas
- 49 Wireless Ideas
- 287 Service & License
- 457 News and Release
- 89 Security Advisories
- 4.3K FAQ
- 96 Security Highlight
