Routing with Point to Point PPPoE WAN subnet
Hi Guys, i have the following situation and I don't figure out from a routing problem.
USG Flex 500 H
WAN1 P2 external zone wan vlan835 unassigned ip
PPPoE zone wan with fixed ip given from my isp only for PTP (no navigation) 172.31.x.x/32
Subnet for navigation x.x.23.128/30 , usable x.x.23.129 and .130
I created this Policy route for internet surfing from lan trough public ip .129
Incoming interface LAN - Destination any , next hop WAN PPP, SNAT ip object .129
Devices on this LAN navigate correctly with ip .129 but I tried to setup a connectivity check and it always fail
How I can tell to Zywall use ip .129 and/or .130 ?
Is it possibile by creating a Virtual ip on that interface?
Thank you
…at the end… I used openwrt before the 500H and solved my problem using all the public IPs in my zywall
Hey please, do you have any ideas for me?
Hi @Mk88_it ,
Could you please clarify whether the IP addresses .129 and .130 should be configured on the WAN or WAN_PPP interface?
To help us better assist you, please provide:
- Screenshots of your current interface configuration
- Screenshots of your policy route settings
Zyxel_Judy
Hello Judy,
Interface configuration
Policy route
With this configuration, if I enable the connectivity check on the routing policy, it always fail
I tried adding another policy for zywall routing with .129 but the ConnCheck always fail too
Thank you
Could be one solution add two virtual ip to FTTHoTA_PPP interface?
Hello @Zyxel_Judy any suggestions?
Hi @Mk88_it ,
Thank you for sharing the detailed information. We are investigating this case and will update you when we have any findings.
Thank you for your patience.
Zyxel_Judy
Hi @Zyxel_Judy do you have something for me?
Hi @Mk88_it ,
We've just returned from the Lunar New Year holiday. Apologies for the delayed response.
Since the solution is related to setting your public IP, we sent it to you via private message in the Community. Please check!
Zyxel_Judy
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
