VLAN on USG200
Hi everyone,I'm using a USG200 firewall to use a VLAN in my case Vlan 20.I configured it on the internal door Lan1 and assigned on the door of my Switch.Everything works if I go to Lan1 from Vlan20, it doesn't work if I go to Vlan20 from Lan1.What's wrong? Thank you
Likely to do with zones did you given VLAN20 a zone? then you need from LAN1 zone to VLAN20 zone
Yes, I created VLAN 20 on the LAN1 zone, and I need to show the two networks. Currently it is unidirectional
Ok because you put them on the same zone you need policy rule from LAN1 to LAN1
I didn't do anything wrong, it was the windows firewall that was blocking everything.thanks anyway
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 79 Switch Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
