Set up MFA / 2FA for IKEv2 on Flex 200h
Hi @PeterUK
First, please ensure your configuration for 2FA VPN access is set up correctly. You can refer to the guidance article below to verify your setup:
[USG FLEX H] How to Set Up 2FA with Google Authenticator for Remote Access VPN and SSL VPN
If you’ve confirmed that the configuration is correct and the issue persists, kindly provide the following details via private message:
- HTTPS WAN remote GUI access information.
- The type of remote VPN you are using.
- A test VPN client account with credentials for us to investigate further.
Kay
Hi @PeterUK
After reviewing your case and the device design, we have confirmed that the VPN 2FA page link can only be accessed once the VPN connection is established.
Regarding the ability to access the VPN 2FA page directly through the WAN IP or LAN IP on port 8008 after disabling the firewall rule, this behavior is consistent with the default design of the current firewall web server and is considered normal.
Kay
Well openVPN was installed in the lower right sys tray for you to try even when VPN was connected you can't get to the 2FA page
So...I worked out my mistake because VirtualBox had IP 192.168.255.43 and 2FA as 192.168.255.39 it didn't go down the VPN testing with another IP subnet to the firewall worked.
stil would like the following
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
