CLI no working on my USG110, but does on my USG60W Help please
To remove the use of RC4 and DES ciphers run the following commands:
Router#configure terminal
Router(config)# no ip http secure-server cipher-suite rc4
Router(config)# no ip http secure-server cipher-suite des
Router(config)# show ip http server secure status
this does not seem to work I end up with
active : yes
port : 443
certificate : default
force redirect : yes
authentication client: no
strong cipher suite : yes
cipher suite : rc4 aes des 3des
ssl protocol : tls1.2
Hi @Ncarbon
Which version is working on your USG110?
I tested it in 4.33 C0 version, there is no this problem.
System Name:BFVPNModel Name:USG110Serial Number:S162L3020XXXMAC Address Range:Firmware Version:V4.33(AAPH.0) / 2019-01-09 09:35:01
I can get in with SSH but the commands don'r seem to remove the ciphers0 -
Router(config)# no ip http secure-server cipher-suite rc4Router(config)# show ip http server secure statusactive : yesport : 443certificate : defaultforce redirect : yesauthentication client: nostrong cipher suite : yescipher suite : rc4 aes des 3desssl protocol : tls1.2admin service control:No. Zone Address Action===============================================================================user service control:No. Zone Address Action===============================================================================1 WAN ALL deny2 LAN1 ALL acceptRouter(config)#0
So I run the configuration however rc4 and des are not removed0
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
