NIS2 - HowTo
Hi everyone,
I need help configuring Zyxel devices in accordance with the NIS2 directive. I am familiar with the general principles of this directive, but I lack detailed information on:
- How to properly configure Zyxel devices according to NIS2?
- What elements should be included in security reports?
- Which vendors are best to collaborate with to ensure NIS2 compliance?
- What are the best practices in the context of Zyxel devices?
I am looking for practical tips and technical materials, not marketing fluff. Any advice and experiences would be greatly appreciated.
Thank you!
Hi @tczauderna
To help you get started, we recommend referring to the following resources that outline Zyxel's approach to NIS2 compliance:
- Use Case and success stories for NIS2 Security:
- NIS2 Security Solution Infographic
These materials provide practical insights into best practices and configuration tips for aligning Zyxel devices with NIS2 requirements.
Additionally, could you please clarify your question about
Are you looking for vendor-specific tools or services, or partnerships to enhance overall compliance strategies? This will help us provide you with more tailored advice.
Kay
Thank you for sharing the NIS2 compliance materials. I need some more details on how to practically apply these rules to Zyxel devices. My main questions are:
Configuring Zyxel Devices to NIS2:
Can you provide a detailed step-by-step guide on how to configure Zyxel devices to comply with NIS2 requirements?
What specific settings are recommended to ensure maximum security in compliance with this directive?
Security Report Elements:
What specific elements should be included in the security reports generated by Zyxel devices?
Can you provide examples of NIS2-compliant reports?
Vendor Collaboration:
Which vendors are recommended to work with to ensure full NIS2 compliance?
Can you recommend specific tools or services provided by selected vendors that support the NIS2 compliance strategy?
Best Practices:
What are the best practices for Zyxel devices to maintain NIS2 compliance?
What specific Zyxel device features should be used to meet NIS2 requirements?
Additional Examples:
Risk Assessment:
Clear interface to check each host for CVE vulnerabilities, with integration with tools such as OpenVAS or Wazuh.
Incident Management:
In case of detection of CVE-related activities, such as SQL injection on a critical host, ensuring automatic cut-off of access in case of critical threat. Integration with incident management systems such as Splunk or IBM QRadar.
Monitoring:
Central monitoring of host and server health, with methodology for connecting to tools such as Nagios or Zabbix.
Compliance Management:
Use of compliance management tools such as OpenSCAP, CIS, PCI DSS, with examples of solutions offered by FortiOS Audit Compliance.
Accounting Office Example:
Example Description: Accounting office with USG 100, GS1930 devices, several hosts, two servers (Windows and Linux) and storage.
Requirements: Due to the size, costs are a factor, so integration with open-source tools such as Wazuh and Zabbix is recommended.
Configuration Details:
Wazuh: Allows monitoring of vulnerabilities on hosts and the number of incidents.
Zabbix: For central monitoring of host and server health.
Automatic Reports: Generate reports on vulnerabilities and incidents.
I would appreciate any advice and experience related to practical use of NIS2 on Zyxel devices.
How did you get that screenshot?
works with different systems. This is a snapshot from FortigateOS - on their UTM. In my backyard I work with Fotigate Zabbix Openvas on a daily basis and now I am slowly starting Wazzuh. So from these systems I can provide PrintScreens or conduct work as part of secure information :)
https://community.fortinet.com/t5/FortiGate/Technical-Tip-How-to-check-PCI-compliance-on-the-FortiGate/ta-p/349364
Hi @tczauderna,
Thanks for your feedback. After checking, we don't have NIS2 technical WP at this moment, however, we managed to create similar material in the near future.
Also, we would like to ask our sales team to contact you and assist you. Would you like to share your contact information with us? I will send you a private message to request.
Zyxel Melen0
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 419 News and Release
- 89 Security Highlight
