Public IP, publish DNS
Need to set up Zywall 110 with public IP-addresses, which we have.
-have two public DNS-server which must be publish to internet
-public IP:s have used also on LAN (dhcp)
What is the best way to configure fw and publish DNS servers?
Firmware 4.32
Public address range:
xxx.65.126.1 - xxx.65.126.256
xxx.65.1267.1 - xxx.65.127.256
xxx.65.126.1 (router)
xxx.65.126.2 (fw)
xxx.65.126.7 (switch)
xxx.65.127.5 (NS1) - public DNS server
xxx.65.127.10 (NS2) - public DNS server
xxx.65.126.10 - xxx.65.126.90 (dhcp)
Hi @Jyge
Only some recommendations:
- Your public DNS default gateway must be the Firewall's ip
- Your firewall Default gateway must be the router's ip
- remove the public ip address os the switch unless it is completely necessary.
- Add a policy rule:
Source: ANY
Destination: Public DNS
Service: DNS
Action: Allow
- Add another policy rule if your DNS are caching:
Source: Public DNS
Destination: ANY
Service: DNS
Action: Allow
I hope it helps you,
Regards
Hi @Jyge
You can add a bridge interface for this requirement.
Go to Configuration > Network > Interface > Bridge Click Add button.
(1) Setup interface, zone and member of interfaces.
(2) Set IP address for this interface
(3) Setup DHCP function for DHCP client.
(4) Add policy control rule for incoming DSN query.
Due to DNS server with public IP address, so port forwarding rule is unnecessary.
- 434 Beta Program
- 174 Nebula Ideas
- 418 USG FLEX H Series
- 297 Security Ideas
- 43 Wireless Ideas
- 269 Service & License
- 416 News and Release
- 87 Security Advisories
- 4.1K FAQ
- 87 Security Highlight
