Console port compatibility with SH-RJ45A from DSD Tech
Hi to all the Zyxel folks reading this message,
serial connection has been part of Zyxel devices I see for a long time… Zywall 2 Plus and Zywall 5 had a serial connection availabe, some with RS232 port some with an RJ45 port.
Today, RJ45 console port is still on latest USG Flex lineup, and I think it's not going away soon.
Thanks to Zyxel for delivert in almost every device with console port a cable for access to that so important interface.
However: it's quite stale.
It's like almost 10 years that RS232 port is not on laptops (excluding PLC-dedicated products) and also USB type A is almost disappearing.
So…
I'd love that Zyxel consider to state compatibility (or not!) with some of the cables RJ45-Console port that are available on the market, if not deliver themselves as a cheap reference to the catalog.
At this page
all the specs, pinout included, can be found for DSD Tech SH-RJ45A
Also… Even Cupertino abticated from Ligthning-nonesense. So please, consider for switches, firewalls and APs the possibility to deliver… USB C port on devices, with a serial interface chip installed
I know, won't be that soon. But who knows? Maybe you'll save even some more precious space on your devices :-)
Thanks for taking the time on this post.
Hi @mMontana ,
Thank you for sharing. From your description, we assume that you suggest for a console cable with 2 connectors as below:
- SH-RJ45A / USB type C connector for Zyxel devices (firewalls, switches, access points) and
- USB Type-A connector for laptop connection?
For future switch models, we will implement the specifications mentioned above. For future access points and firewalls, we will carefully evaluate these requirements.
Zyxel_Judy
0 - SH-RJ45A / USB type C connector for Zyxel devices (firewalls, switches, access points) and
That could be an option.
Otherwise, integrate USB-C and serial chip into "big enough" devices (firewall, switches) with standard pinout of the connector (some sort of short-ESD protection too), avoiding the necessity of "custom hardware" for… Computers, laptops, tablet… smartphones? :)Side opinion: APs are more and more power demanding but also… software-feature rich and with computational power. Therefore, as firewalls are requested to "manage" traffic (and not only forward).
In your project i can understand…
on one hand, serial interface is local and really useful for debugging/resolving not properly functional hardware
on the other hand alwas a possible security issue, with standard connections0
- 603 USG FLEX H Series
- 481 News and Release
