NXC2500 and AP Firmware
BAAG
BAAG Posts: 2 image  Freshman Member
We still use an NXC2500 and this Controller still works fine for us. 😅
But now we bought a new AP (WAX510D) and this particular Firmware is very outdated on the Controller. How can I update AP Firmware to deploy this Firmware to all connected AP's?
It's this the way to go, or is this only for Controller Update?
https://community.zyxel.com/en/discussion/22779/nxc2500-firmware-update
Thanks and best regards
Bernhard
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,616 image  Zyxel Employee
    Hi @BAAG,
    If your NXC2500 haven't upgraded to the latest firmware, please follow that post to upgrade. In addition, if you want to use WAX510D with the latest firmware version, please consider using standalone/Nebula mode. This is because NXC2500 doesn't support newer AP firmware.
    Zyxel Melen
  • BAAG
    edited January 2025
    Thank you for your answer. Our NXC2500 is on the latest Firmware. I want to update the firmware for the WAX510D in the NXC2500.
    Nebula is not an option for us, because I will never let a Cloud Solution host our Switches/AP's/Firewall etc. And Standalone is too complicated…
