Using Forticlient with ATP200
We have a requirement to use Forticlient to connect to an ATP200 .. the client connects to multiple VPNs .. and the Forticlient keeps knocking our the Windows native VPN
Is it possible ? .. to use Forticlient with Zyxel ATP200 .. currently we are connecting with IPSec VPN .. but will do SSL VPN if that is the way to make it work
If yes, do you have instructions .. especially in the configuration of the Phase 1 & 2 parameters (where do I find them in the ATP200 control panel)
I did some test and it doesn't seem to work.
Forticlient interface has all fields with coherent values, but client side it says "no response from the peer" and server side 5 IKE messages are recorded (only "INFO" ones, no warning nor error)
2025-01-21 16:21:30
info
IKE
Recv IKE sa: SA([0] protocol = IKE (1), AES CBC key len = 128, HMAC-SHA256 PRF, HMAC-SHA256-128, 2048 bit MODP; ).
IKE_LOG
412025-01-21 16:21:30
info
IKE
Recv:[SA][VID][VID][VID][VID][VID][VID][VID][VID]
IKE_LOG
422025-01-21 16:21:30
info
IKE
The cookie pair is : 0x5d15cc7a0b89b73e / 0x179f272d960544f1
IKE_LOG
432025-01-21 16:21:30
info
IKE
Recv Main Mode request from
IKE_LOG
442025-01-21 16:21:30
info
IKE
The cookie pair is : 0x179f272d960544f1 / 0x0000000000000000
IKE_LOG
Page
of 1
Show
items
Displaying 1 - 5 of 5USG FLEX 200
Hi @Force12,
Forticlient is for Forti device only. For ATP200, you may consider SecuExtender.
Zyxel Melen1 -
You can find Phase 1 & 2 parameters under settings → VPN → IPsec VPN.
2025-01-21 16:21:30
info
IKE
IKE_LOG
info
IKE
IKE_LOG
info
IKE
IKE_LOG
info
IKE
IKE_LOG
info
IKE
IKE_LOG
Page
of 1
Show
items
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 79 Switch Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
