USG flex H in HA configuration
Hello everyone,
I operate 7 USG flex 200HP at 4 locations. HA operation at three locations since v1.31. This works well.
However, I have a problem at one location: There is a fiber modem, a DOCSIS modem and a Zyxel FWA710, all in IP passthrough (bridge) mode. This works well as long as all three modems are connected directly to the active node USG WAN ports.
Is it possible to configure a (Zyxel-) switch in such a way that these three modems are automatically available to the passive node USG in the event of a takeover?
Thanks, Holger
Hi @Holger_AZ,
So, your purpose is to have a switch to check the downlink USG FLEX 200H to help the redundance?
Zyxel Melen0 -
Hello @Zyxel_Melen,
The question is how I can automatically make the three modems (and thus the three WAN connections) available to the second USG in the event of a redundancy takeover. I tried with three VLANs on an XMG1915, but the modems' WAN IPs are not assigned to the USG's WAN interface. Maybe I made a mistake?
thx, Holger
I found my mistake. ALL ports of the VLAN must be in access mode, then IP passthrough works...
Thanks, Holger
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
